Go Back   Focus Fanatics > Non-Performance Ford Focus Discussions > Interior Mods & Upgrades Chat
Interior Mods & Upgrades Chat The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades.
Thread Tools Search this Thread Display Modes
Old 11-28-2005, 10:32 PM   #1
jabber
jabber's Avatar
Fan#: 24679
What I Drive: 2002 Black SE
FF Reputation: 1 jabber Good Standing Member
Buy-Sell-Trade Rating: (4)
Questions about wiring
I'm hoping someone can give me a hand. This is what I want to do: I want to hook up some neons for under my front seats so that there is some light in the back of my sedan. I would like these lights to come on when the doors open. I know that I can go through the dome light for this. I would also like to have two switches. One switch would be a main switch that would turn the power to the neons on and off. The second switch would turn the "door activated" part off, ie. the neons would be on all the time whether the door was open or not if the switch was off and if the switch was on, the neons would only come on when the door opens. I'm sorta new to automotive wiring, and i'm not sure if this will work or not, and am hoping someone can confirm or reject my idea!! Also, what gauge of wire do i need to wire up the neons (i'm actually going to buy cold cathode tubes, but that shouldn't make a difference)!! Thanks to all who read this and to those who were able to offer some insight... many many thanks!!
-Ben
jabber is offline   Reply With Quote
Old 11-29-2005, 11:45 PM   #2
jabber
jabber's Avatar
Fan#: 24679
Does no one want to help me or what??? PLEASE??
Old 11-30-2005, 12:59 PM   #3
morduin
morduin's Avatar
Fan#: 5299
What I Drive: '03 Twilight ZX5 PZEV
FF Reputation: 1 morduin Good Standing Member
I wanted to do the same thing so im curious. For power I would suggest just soldering a 16 gauge power wire directly to an unused fuse, then a 16 gauge ground wire screwed under one of the fusebox corners. You can wire the power directly to a switch or go with your ideas from there. No need to use your own fuse if you just tap off your fusebox also, saves trouble. Cathodes really don't take up much power. If you get them I highly recommend oznium.com
morduin is offline   Reply With Quote
Old 11-30-2005, 01:58 PM   #4
jabber
jabber's Avatar
Fan#: 24679
Yeah, I've heard oznium is great! That's where I was planning on getting them from. My question is whether having the two switches will work. It's really the only thing I'm not sure of. I really like the idea of having them come on when my door opens, but I also like the idea of having them on all the time with the flick of a switch. Maybe... if I turn on the interior light with that switch... the cathodes will come on too if they are hooked up to the dome light??? Do you know??? Thanks for the help and advice though! Let me know if you end up doing it!!!
-Ben
Old 11-30-2005, 02:45 PM   #5
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
What I Drive: 2003 White zx3 2.3L
FF Reputation: 16 Foci_Fosho Great Standing Member
Buy-Sell-Trade Rating: (6)
I believe, what you need to do... is use a relay and a switch.
edit:
because I have a feeling some people might not be familiar with wiring a relay
http://electronics.howstuffworks.com/relay1.htm
Foci_Fosho is offline   Reply With Quote
Old 11-30-2005, 04:05 PM   #6
jabber
jabber's Avatar
Fan#: 24679
From what I understand from that link is that using a switch and a relay will only allow me to power the lights on and off, isn't that what is said? I'm not familiar at all with relays, so maybe i'm incorrect. Please advise!!
Thanks
Old 11-30-2005, 10:01 PM   #7
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
you have no idea how long this took me to draw, like 1/2 hour... haha
This is what I've come up with for you... Just add a switch to a 2nd power source and you should be set.
Old 11-30-2005, 10:02 PM   #8
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
oops, forgot to attach pic
Old 11-30-2005, 10:07 PM   #9
jabber
jabber's Avatar
Fan#: 24679
Thanks so much!!! I appreciate all your time and effort. So, the switch goes between the battery and the relay, is that correct? Thanks again for the help!
Old 11-30-2005, 10:32 PM   #10
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
Well If you put a switch between the battery and relay... then that will just enable/disable the cold cathodes from turning on with the map light.
If you want it to come on/off regardless---
Add a switch from the battery to the power invertor...
You can splice into the wire that goes to the relay from the battery, and add a switch with the other lead going to the (+) on the power-invertor.
Old 12-04-2005, 01:07 PM   #11
jabber
jabber's Avatar
Fan#: 24679
Alright, I think I have the idea of how to do this now, but I'm not sure how wiring a relay works. How do I buy it (what kind of current and voltage?) And if I put a switch between the battery and the power invertor, I will be able to turn the lights on with that switch, and then when that switch is off, the lights will come on with the door, right?? Thanks so much for all your help!
-Ben
Old 12-04-2005, 03:10 PM   #12
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
----- Yes
------ Best bet is Radio-Shack. Just tell them you need a 12v relay... I believe relays designed for Automotice uses (like car alarms)... have the relay encased in plastic with colored wires sticking out...That might be the best to use. They cost $5 or less.
If that fails... try autozone.
Bookmarks
Search this Thread:
Advanced Search
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
