Go Back   Focus Fanatics > Ford Focus Tech Discussions > ZETEC Performance (2000-2004)
Old 10-12-2005, 02:55 PM   #1
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: Blue Schnell & Gray Iguana
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
Post Zetec Engine History
Found this on the Contour site I visit. Contours have the Zetec engine too and I thought that I'd share this info with the Focus Zetec owners.
Ford Zetec Engine
The Ford Zetec is a name used on many inline 4 cylinder automobile engines. All are multi-valve DOHC engines, but they are based on three distinctly different designs.
It is used in cars such as Ford Mondeo, 1995-2000 Ford Contour/Mercury Mystique, 1999-2002 Mercury Cougar, 2000-2003 Ford Escape/Mazda Tribute, 2000-2003 Ford Focus and 1998-2003 Ford Escort ZX2. It has been made in 1.25L, 1.4L, 1.6L, 1.7L, 1.8L, 2.0L and 2.3L capacities.
The Zetec is also the basis for the Formula Ford 2000 series from 2003 where it replaces the older Ford Pinto and Ford Kent.
Zetecs for Europe are built in the Bridgend, Wales and Valencia, Spain plants. American engines are built in Chihuahua, Chihuahua, Mexico. Asian Zetecs are built in Chung Li, Taiwan. South American Zetecs come from São Paulo, Brazil, and more are built in Inonu, Turkey.
Zeta
See Ford Zeta Engine for more information.
Production of the larger Zeta family of Zetec engines lasted from September, 1991 through December, 2004. Displacement ranged from 1.6 L to 2.0 L. It was replaced in most applications by the Mazda MZR-based Duratec 20, though some Zetec-SE engines were used as replacements on the lower end. Ford Power Products sells the Zeta in 1.8 L and 2.0 L versions as the MVH.
Zetec
The first Zetec engine appeared in 1992, powering the fourth generation of the European Ford Escort and Orion. It was codenamed as the "Zeta" engine before Italian car maker Lancia threatened to sue Ford for trademark infringement as it already owned the name. Ford hurriedly renamed the engine "Zetec".
Early versions of the engine (prior to mid 1998) came complete with self-adjusting hydraulic valves. This helped prevent the notorious valve tapping (on the CVH) but caused other issues. The biggest problem was that a special Ford formulation of oil was required otherwise the valves tended to stick. Similarly, failure to regularly rev the engine above 4000 rpm also led to valve sticking. For these reasons, conventional tappets with shims were introduced in 1998.
2.0
The 2.0 L Zetec shared its 84.8 mm (3.339 in) bore and 88 mm (3.465 in) stroke with its predecessor, the 2.0 L 2-valve CVH.
A high 10.2:1 compression ratio and larger valves contributed to the SVT version's much-higher output.
Applications:
1999 Ford Escort, 130 hp (97 kW) and 127 ft.lbf (172 Nm)
2000 Ford Focus, 130 hp (97 kW) and 135 ft.lbf (183 Nm)
2002 SVT Focus, 170 hp (127 kW) and 145 ft.lbf (197 Nm)
Zetec-E
Later versions of the engine are known as the Zetec-E. The main difference is a two-piece crankcase which helps damp out noise and vibration.
Sigma
See Ford Sigma Engine for more information.
The advanced Zetec-SE was developed in collaboration of Yamaha under the Sigma codename. It ranges in size from 1.25 L (1249 cc) to 1.7 L (1700 cc). It is extremely different from the Zeta engine - the intake and exhaust are even on opposite sides. It is also sold as a crate engine by Ford Power Products as the ZSG.
Zetec-SE
This is the primary Sigma engine. It is sold under the Sigma name in some regions, while Mazda uses the MZI name.
Applications:
1.25 L
Ford Fiesta
1.7 L
Ford Puma
Zetec-Rocam
In 2000, Ford of Brazil developed a cheaper version of the Zetec-SE engine, to compete with the classic VW AP engines. It is 8v SOHC instead of 16v DOHC and its body is made of iron instead of aluminum. Also, its camshaft is driven by a chain instead of a belt. As a result this engine exhibits rougher behaviour, producing more vibration and noise.
On the other hand, it has a superb torque output thanks to the addition of the Rocam (Rollerfinger Camshaft) feature. It's also a much smaller engine than the SE version, which allowed it to be installed on the Ford Ka, replacing the Endura-E engine which by that time was considered underpowered and outdated.
The engine also featured a new patented process for the aluminum head production, which resulted in a better alloy than those produced in Spain and UK, and at a lower production cost.
In 2002 a supercharged 1.0 litre (95hp) version was released for the Ford Fiesta, to compete with the 1.0 turbo 16v (110hp) version of the VW Golf.
In 2003 the Zetec-Rocam engine was introduced in Europe, but labeled as Duratec 8v, for the SportKa and StreetKa models. Later a 1.3 litre version was also released as an option for the standard model, but the European versions of the engine are produced in the South Africa plant.
In October/2004 a newer bi-fuel version was introduced labeled "1.6L Flex", capable of running on both petrol and alcohol, even mixed at any proportion. This version also featured "Compound High Turbulence" chambers, as used on the CHT engine.
Currently, this engine powers nearly all Brazilian Ford models - except those with 2.0 litre engines - in many different variants:
65hp 1.0L (Ford Ka)
95hp 1.6L (Ka Action, Ka XR)
69hp 1.0L (Ford Fiesta, Ford Ecosport)
95hp 1.0L Supercharger (Ford Fiesta, Ford Ecosport)
99hp 1.6L (Ford Fiesta, Ford Ecosport)
110hp 1.6L Flex (Ford Fiesta Sedan)
RoFlow Zetec
The Zetec was superseded by the Duratec series of engines, originally called RoFlow Zetec. These are based on the Mazda MZR engines.
Duratec
See Ford Duratec Engine for more information.
Two things you should learn from this;
1) Pre 1998 Zetecs came with self-adjusting hydraulic valves.
2) Zetec (an engine code name) is nothing like Vtec (a variable cam timing technlogy).
SOURCE
Just reading.....
microtonal is offline
Fan#: 1
Old 10-12-2005, 03:23 PM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 68 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Great find Micro, I stickied this also as I've seen questions in the past come up occasionally that are ALL answered by this post. Very nice!
Chad (S2)
S2 is offline
Old 10-12-2005, 04:15 PM   #3
zetectour
Fan#: 22092
What I Drive: 1997 Ford Contour
FF Reputation: 1 zetectour Good Standing Member
That's my post.
SleeperZ on CEG - Zetectour on FJ
SleeperZ on FCO - Zetectour on FF
Pre98 Contour Zetec - Some Mods
zetectour is offline
Old 10-12-2005, 07:20 PM   #4
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
Originally posted by zetectour
That's my post.
Good research and gathering of the info.
I must of searched Zetec I don't know how many times and never found the info you found, gathered and posted.
Just reading.....
Old 10-12-2005, 10:59 PM   #5
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Yeah same here, a while back someone asked the question "What does Zetec stand for?" and I searched for a good hour, couldn't find anything remotely as 'detailed' as what you posted.
Chad (S2)
S2 is offline
Old 10-12-2005, 11:37 PM   #6
Chick
I like cake
Chick's Avatar
Fan#: 151
What I Drive: '11 Fiesta SES, '13 Civic Si Sedan
FF Reputation: 133 Chick Excellent Standing MemberChick Excellent Standing Member
Buy-Sell-Trade Rating: (37)
Is this from Contour.org cause it looks like I seen it over there.
But great info. Hopefully this will answer a lot of questions!
February 2005 ROTM
2011 Yellow Blaze Fiesta SES
2013 Taffeta White Civic Si sedan
Focus Fanatics Forum Rules
Ride of the Month Showcase & Voting Center
Chick is offline
Old 10-13-2005, 01:09 AM   #7
AC21365
AC21365's Avatar
Fan#: 2039
What I Drive: See Sig..
FF Reputation: 2 AC21365 Good Standing Member
Re: Zetec Engine History
Originally posted by microtonal
Zetec
Early versions of the engine (prior to mid 1998) came complete with self-adjusting hydraulic valves. This helped prevent the notorious valve tapping (on the CVH) but caused other issues. The biggest problem was that a special Ford formulation of oil was required otherwise the valves tended to stick. Similarly, failure to regularly rev the engine above 4000 rpm also led to valve sticking. For these reasons, conventional tappets with shims were introduced in 1998.[/B]
Very interesting!! I had always wondered if ford had always used solid tappets in the zetec. Looks like they did in fact use HLA's (hydraulic lash adjusters), kinda odd though that you needed special oil to make them work right. By BP series mazda motor has hla's, all I need is 4 quarts of the cheap stuff and I'm good.
Intersting too, Ford used the CVH design in the zetec's design.
Good stuff man
Past: 2001 Blue Focus ZX3 - ('03-'05) Boltons and S2 wing. I miss you
------2001 Red Focus ZX3 S2 - ('07-'12) Have fun at Auction
------2008 Red Mazdaspeed 3 GT - ('08-'11) Sold
Present:
2005 Silver Focus 2.3L ST Sedan - 5-speed w/all the options
AC21365 is offline
Old 10-13-2005, 07:58 AM   #8
pio
pio's Avatar
Fan#: 198
What I Drive: 2012 Black Mustnag GT
FF Reputation: 2 pio Good Standing Member
thats the same info i found on another page...dont remember the page...
it was posted on the thread chad mentioned above...
BTW...move to zetec owners lounge
My focus is not even a shadow of what it once was...
pio is offline
Old 10-13-2005, 09:05 AM   #9
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
If you click on the SOURCE link at the bottom of the first post, it leads back to the Contour.org forum where I got the info.
Just reading.....
Old 10-13-2005, 09:59 AM   #10
viney266
Moderator
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
FF Reputation: 112 viney266 Excellent Standing Memberviney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Agreed! Nice find .. Good stuff!
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
