Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 03-06-2013, 04:17 PM   #1
mrdeath2000
Fan#: 91996
What I Drive: 2006 silver zx4 se
FF Reputation: 2 mrdeath2000 Good Standing Member
wheel bearing, thought it was a worn tire
Thought I had a worn tire (the sides are pretty worn) from the sound it was making. Kinda like my meaty Jeep tires. Turns out it was a wheel bearing from those damned autozone drum brakes (lasted 15 months ~25-30,000miles).
30 minutes to swap them, luckily under warranty, hope there's no hassle taking both back.
What really led me to noticing it was a bearing not a tire is driving over a cement section of road after an asphalt section. THe sound didnt change, a tire problem it would have.
The drums were fine, just the bearing. Getting a press soon I think and if they last a few months I'll be ok and just press in some timkens.
2006 Focus ZX4 SE Auto -commuter
mrdeath2000 is offline
Fan#: 1
Old 03-06-2013, 04:55 PM   #2
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
FF Reputation: 4 Milton Good Standing Member
Did you replace the bearings 25,000 miles ago?
Milton is offline
Old 03-06-2013, 05:00 PM   #3
mrdeath2000
Fan#: 91996
I did brakes 25,000 miles or so ago. Autozone showed a purchase date of 12/8/2011. So they wern't originally replaced because of bearings, but because it needed brakes and they come with the bearing pre-pressed in.
I just thought I would pass on the info of deferring the difference between bad camber wear on a tire vs bearing.
I've had bearings go bad in the past, buy they usually had a little grind in the noise to them.
Old 03-06-2013, 05:09 PM   #4
Milton
Fan#: 89715
Asking because I was thinking if using pre-pressed bearings, but had concerns about the bearings used. Guess I'll press my own.
Thanks
Milton is offline
Old 03-06-2013, 05:16 PM   #5
mrdeath2000
Fan#: 91996
pre-pressed isnt bad. What my searching shows is that the duralast/el cheapos bearings have plastic cages for the bearings and that's what fails.
If you have a press, you can do it. Check Rockauto, i think timkens are about $25 each.
Old 03-06-2013, 05:38 PM   #6
USARice
USARice's Avatar
Fan#: 56127
What I Drive: 2005 Silver ST, DD and AutoX
FF Reputation: 1 USARice Good Standing Member
Buy-Sell-Trade Rating: (4)
I fail to understand why the Focus goes through so many rear bearings. I had 3 tRacers and 1 Escort all in excess of 100k and never did a single bearing. I am at 95k on my FoFo and will be doing my 3rd rear bearing in under the last 50k. Good grief. :(
Sent from Gods Country
No, my avvy isn't a B&W photo....meet Jaz, the car that makes any pic look monochromatic!
USARice is online now
Old 03-06-2013, 07:35 PM   #7
Milton
Fan#: 89715
3 sets of rear bearings in 95K
3 sets of rear bearings in 95K is excessive!! My 2007 Focus SES has ~85K miles and it's on the original set of rear bearings.
No offense man but I would have to think you have an issue some place else such as other damage/worn parts causing premature failure, using extremely inferior parts, improper replacement procedures or improper lubrication.
Milton is offline
Old 03-06-2013, 08:19 PM   #8
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
The bearing will die way prematurely if not torqued to the full torque spec. Also, many of the 'lifetime warranty' Autozone and O'Reilly bearings are crap, I personally experienced one with absolutely no grease in it, failed starting first day. The replacement BCA has been running for a long long time now. Not even pressed, knocked in with a hammer but doable if one knows how. Almost every one I do like that, none dead yet. Got a hammered in rear Focus drum one now that's been in car at least 3 years. People here say Timken is good.
amc49 is offline
Old 03-06-2013, 09:11 PM   #9
gfaemrvk
Fan#: 110972
What I Drive: 2010,red,bmw
FF Reputation: 1 gfaemrvk Good Standing Member
gfaemrvk is offline
Old 03-06-2013, 10:22 PM   #10
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
that's an excellent observation.
When my rear bearing went out, it blindsided me because I had cupped tire noise on the rears for so long that I was in the habit of ignoring any growl from back there.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
