Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 12-15-2012, 09:53 AM   #1
2000blackzx3
2000blackzx3's Avatar
Fan#: 9744
What I Drive: 2002 SVT Focus
FF Reputation: 21 2000blackzx3 Great Standing Member
Custom rear spring perches
I'm looking for ideas as far as getting some spring options in the rear. I have FK coilovers 400F/350R right now, and I'm considering using SWIFT coilover springs (at least for the front) with revalved Konis, but I may try to fab some rear perches that would allow me to fit standard diameter coilover springs on the rear control arms.
What have you guys done to get 400+ spring rates at the rear? What are the options without a custom bottom spring seat? Any spring seat I can source somewhere without making one? (My FKs are installed with the adjustable perch at the top, and the spring fits in the original control arm location at the bottom). I thought about bolting a machined spring perch through the arm, sandwiched with a plate (big washer) underneat.
What spring rates would you suggest for mostly autocross, and maybe some road racing? I'm thinking about 500F/500R as a starting point. I have 21mm F and 24mm R sway bars, and will run in FSP next year on C71 Z214 in 225/45/15 if budget allows. A Torsen LSD will be installed. The car was close to neutral this year, but could use a little more stiffness at the rear.
Here's a reference pic (not my car) :
Show us your setups!
2002 Sonic Blue SVTF
2012 Canadian ASN FIA Autoslalom Champion
2012 CADL Street Touring & Overall Champion
2012 Club Delta Québec Street Touring Champion
2000blackzx3 is offline
Fan#: 1
Old 12-15-2012, 12:01 PM   #2
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
FF Reputation: 28 thenorm Great Standing Member
KW coilovers have the spring seat at the bottom like you are talking about.
my old FS thread has some pictures of the orignal seats, plus some custom ones i machined to gain some height.
http://www.focusfanatics.com/forum/showthread.php?t=283747
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 12-15-2012, 12:51 PM   #3
2000blackzx3
Fan#: 9744
Thanks for the pics, from what I can see you use the control arm hole as centering and its top edge as the vertical contact surface. Are the 3 screws for tightening the perch to the arm with the black washer from underneath? (I just want to eliminate any possible clunking if it's not tightened, stock springs clunk if rubber is removed from the bottom coil)
Any input on existing spring diameters and heights commonly available to test different spring rates? I guess I will use my FK perch at top and fit a machined perch for the same I.D. at the bottom. That KW bottom perch is 3 parts right? Male threaded top part with hexagonal hole accessible from underneath, female threaded bottom part and washer to tighten the part from underneath? Am I right on this?
Old 12-15-2012, 05:24 PM   #4
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
I've heard dominant Engineering has some good set up maybe we can make you a coilover bottom seat with his tubular control arms
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is online now
Old 01-03-2013, 08:52 AM   #5
ecugrad
Fan#: 99968
What I Drive: 2002 Sonic Blue Ford Focus SVT
FF Reputation: 1 ecugrad Good Standing Member
Here is what I did:
You can get those perches on ebay for under $25 for a pair. I used a 6" x 2.5 x 400 lb rear spring with a Hypercoil Tender spring to keep the spring from falling out. Its slightly lower than the stock SVT springs. I wish it were a tad lower. No rattles and feels good on the street.
2003 Sonic Blue SVT Focus- Prepped for STF
Going slower than no man has gone before....
ecugrad is offline
Old 01-04-2013, 03:52 PM   #6
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
Would it help you guy's to run Steeda's 28.6mm/1 1/8th rear sway bar?
Interduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 01-04-2013, 04:00 PM   #7
ecugrad
Fan#: 99968
already do
Sent from my SCH-I510 using FF Mobile
ecugrad is offline
Old 01-04-2013, 04:16 PM   #8
felixthecat
Fan#: 80663
Originally Posted by ecugrad View Post
already do
Me too, upgraded from Eibach's 25mm. I was just mentioning to the other guys above. Kind of surprised they don't w/ dia weight transfer.
