Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
#21 | ||||
FF PHOTOG ENTHUSIAST
Nice.
-Ray-
22ST FF PHOTO CONTEST HAS BEGUN CLICK HERE TO JOIN IN TO THE PHOTO FUN. ALL ARE WELCOME. Hatch Nation Member: #147 TeamFocalize Head Honcho R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
#22 | ||||
You should learn to use the oversteer to your advantage, In a front drive car the way to keep from spinning is the opposite of what you are currently doing. Mash the go pedal and point the fronts where you want to be. The tail will follow. Not the fastest way around all corners since you are bleeding energy while sliding, but a good way to get around some of the tight stuff that would other wise be painfully slow. Turn in... make a sandwich... rotate and go. A good example of where to use a drift would be a tight Chicago box, or set of 90° turns.
Also getting some front camber on a McPherson strut will help when you autoX.
-Rally Russel check out my rally focus site: Http://www.rallyrussel.com |
#23 | ||||
quickly, I run -2.4 camber in front per side, -0.18 toe front. -2.2 rear camber per, 0.0 rear toe. Eibach sways front and rear, front Koni yellows full stiff, rear koni 1-1 1/2 turns off full stiff. if she plows ill soften up the front half a turn. LFB FTW!
#87 STF MASSIVE SPEED SYSTEM 2000 Focus Sedan 2012 Chicago and Milwaukee Regions SCCA STF Season Champion |
#24 | ||||
Front camber is going to change the car entirely if you've been running with NO front camber... Its definitely going to help to keep the front end from pushing through turns.
2011 SES 5spd #006 >> SR #213 Join the cause! 3 Door Fords for America! facebook.com/3DRS4US The internet is for finding an answer, not for finding ways to ask a question. |
| Thread Tools | |
| Display Modes | |
