Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 04-12-2012, 07:36 AM   #11
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
FF Reputation: 23 wrc_fan Great Standing Member
Originally Posted by tukaniSVT View Post
What do you guys think about deleting the front Sway?
Some of the Civic guys have told me try that ... but I am hesitant.
-Ray-
Of course the civic guys say that, they have double a-arm fronts and huge spring rates. Already at zero camber up front, it will get worse with out the sway bar. If you want to test it though, all you have to do is disconnect the front sway bar endlinks, let the sway bar just come along for the ride:D
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 04-12-2012, 09:41 AM   #12
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2008 Edge SEL
FF Reputation: 32 tukaniSVT Great Standing Member
Hmm ... but what are your thoughts ... good or bad.
Do you think I would be able to rotate the rear more with out a front sway? Do you think I would oversteer the car too much?
Man ... like Sleepyboy told me once, I need to find an open-empty parking lot and try it out.
-Ray-
22ST FF PHOTO CONTEST HAS BEGUN
CLICK HERE TO JOIN IN TO THE PHOTO FUN. ALL ARE WELCOME.
Hatch Nation Member: #147
TeamFocalize Head Honcho
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 04-12-2012, 12:11 PM   #13
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
It’s tough to say how the car will perform. The inside tire will lose less grip in the corners; the lack of sway bar not transmitting the load. But, you will have a lot less roll resistance, so as the body rolls, the tires are pushing over in to big positive camber, and your contact patch gets really crappy ): So you could have a little more grip, or you could lose a lot.
My guess, you’ll lose grip. There won’t be enough roll resistance, even with the HR spring rates. FWD cars I’ve heard running without a front sway have been running 600+ lb-in spring rates. But I’m not an expert by any means, that’s why I recommend testing it.
Parking Lot Hero
wrc_fan is offline
Old 04-12-2012, 03:45 PM   #14
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
Hmm ... I guess I am going to need to find a nice empty parking lot and go for some practice cone runs.
-Ray-
Old 04-14-2012, 11:03 PM   #15
focus'N'SHO
focus'N'SHO's Avatar
Fan#: 41331
What I Drive: 2000, twilight blue ZX3
FF Reputation: 1 focus'N'SHO Good Standing Member
Well other than getting more front camber. As far as your damping rates have you thought about 3 and 7 or 2 and 6? From what you were saying I'd say the 3 and 7 would probably be about the best compromise. I'm running the same spring setup and trying to dial mine in as well. But I have a 25mm rear bar, with poly bushings on the stock front.
I've been out of the game for a few years till last year though. And I still have a couple of repairs in the rear suspension to do. (parts are here though).
I would do as you have been thinking and use a big empty parking lot and do some testing. I'll admit I used to use one of the local high school parking lots for testing when school was out for the summer :D
2000 ZX3 twilight blue, MTX, bolt ons, cams, and plenty of handling goodies. Finishing up work to get it back on the auto-x course.
1988 Bronco. 351W, C6, 4x4, rusty body, soon to get sold to buy more upgrades for car.
focus'N'SHO is offline
Old 04-14-2012, 11:28 PM   #16
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
FF Reputation: 28 thenorm Great Standing Member
-Ray-
Omni runs with no front bar, but he went to 900# springs to increase the roll resistance ( I'm not sure his rear springs).
But seriously, u need front camber. It is one of the biggest things to help!
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 04-15-2012, 03:45 PM   #17
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
Thanks.
Yeah, I will be ordering the front camber kit by my next gig check.
focus'N'SHO - > I also have the VF Poly mounts up front ... all of them. And the Eibach bar I have is also 25mm.
I have dialed in those numbers ... I just need to get used to the settings when I turn.
Working on a location that I can safely test out the changes. Getting cones from some buddies.
-Ray-
Old 04-16-2012, 08:18 AM   #18
focus'N'SHO
Fan#: 41331
Thanks.
-Ray-
I meant I had poly bushings on the stock front sway bar. I'm working on the engine mounts, my main focus has been handling.
I look forward to hearing what you find. I can't do any real testing of mine at the moment till engine is finished back up, and I do some work on the rear suspension. My rear end is very unpredictable due to enlarged holes where the toe arms mount to the subframe.
Old 04-16-2012, 09:45 PM   #19
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
Ah ... gotcha.
And most definitely will report my findings.
Are you re-building your engine?
I have an extra SVT engine in my garage that one day I hope to rebuild as a back up.
-Ray-
Old 04-17-2012, 07:24 AM   #20
focus'N'SHO
Fan#: 41331
I hit a pothole and it managed to throw a rock up into my timing belt. With the old grind Crower 2's in there that didn't fare too well for my valves. Luckily I had a spare head in the garage with some mild porting done to it waiting to go on. After some custom fitting to the buckets it is now on and getting ready to time it. Plus hoping to do a couple more mods to it while I'm at it. Also like you I have a built HC short block sitting in the garage waiting on me to go through it and make sure everything is good before it gets thrown in.
While I do the rear suspension though it is also getting a rear disc swap :)
