Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus Technical Chat
Ford Focus Technical Chat This section is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls.
Thread Tools Search this Thread Display Modes
Old 11-06-2009, 09:43 PM   #1
sd102884
FF Member#: 70283
What I Drive: 2206 White focus
FF Reputation: 1 sd102884 Good Standing Member
06 Focus Revs High at startup
2006 Ford Focus. When starting the car revs to about about 3,200 rpms. Then it slowly goes down over a one minute or so. Check engine light is on. Recently Had the Idle air controll valve replaced but it stills revs high. The light was off for about 3 restarts and came right back on. Any help would be greatly appreciated.
Maybe its a throttle pos. sens.
or leaky vac hose?
sd102884 is offline   Reply With Quote
Old 11-07-2009, 12:01 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
FF Member#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 187 whynotthinkwhynot Excellent Standing Memberwhynotthinkwhynot Excellent Standing Member
I doubt it's a TPS. Have you had the CEL checked to see what it is? That might give a clue. It sounds to me like your throttle plate is held open somehow possibly the throttle cable is stuck or the throttle plate is stuck open. I'd remove the air intake tube and see if the throttle plate is seated properly, and work the throttle by hand to be sure it's not sticking open.
You can also remove the TPS to be sure that someone didn't fiddle with it. 2 screws hold it in, but if you remove the screws before the TPS, it should tilt slightly. This way the TPS lines up correctly with the throttle shaft. If someone removed it and put the TPS straight in, then it would not be working correctly. It doesn't fit flush like that either, you have to force it in with the screws. The TPS should fit flush without the screws in there, but you'll have to tilt it backwards for the screw holes to line up if you've installed it correctly. If you find that someone installed the TPS incorrectly, then you're most likely going to need a new one.
Moderating Tech Chat and Duratec Chat, let me know if I can help.
whynotthinkwhynot is online now   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Copyright 2002-2009 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
