Go Back   Focus Fanatics > Ford Focus Discussions > EcoBoost & Forced Induction Chat
EcoBoost & Forced Induction Chat The place to chat about EcoBoost or aftermarket turbocharger, supercharger and Nitrous systems.
Thread Tools Search this Thread Display Modes
Old 11-03-2009, 02:28 PM   #1
NCedillos
Still The Best SPI
NCedillos's Avatar
Fan#: 50780
What I Drive: 2002 French Blue SE
FF Reputation: 7 NCedillos Good Standing Member
Buy-Sell-Trade Rating: (9)
Turbo Maintenance
I'm just making this thread because I'm getting some 100,000 maintenance done to my car. The other weekend I was at a Focus Cruise meet and my car was making a weird ticking sound, I took it to a family friend mechanic and it was stuck lifters so I'm getting those all replaced as well as
timing belt
water pump
timing belt tensioner
accessory belt
02 sensors
crank pulley
Idler Pulley
PCV Valve
Coil pack and Wires
Spark Plugs
I'm not too familiar with turbos in general (still learning) so I will be having my boyfriend ehancock help me out with my turbo build. But my main question is that is there anything I should do maintenance wise before I put the turbo kit on? I have all the parts but the oil lines, wideband, gauges, tune. Just the finishing parts. Any help would be appreciated. I jsut want to make sure it can be prepared as much as possible safety wise for my turbo.
And I will be making a turbo build thread since this is for the SPI and there really isnt that many threads about this other than jeffescort really.
Thanks!
Sedan Revolution #68
~SOTM OCT 08~ROTM NOV 09
NCedillos is online now   Reply With Quote
Old 11-03-2009, 03:21 PM   #2
ChuckDee
Team Focalize FTW!!!
ChuckDee's Avatar
Fan#: 43589
What I Drive: 01 black ZTs
FF Reputation: 47 ChuckDee Great Standing Member
maintenance wise, if you're gonna replace all those parts mentioned in the list, you should be good to go. what are looking to push boost wise?
unique(adj): to break off from the crowd and do your own thing
zetec crew#232
ChuckDee is offline   Reply With Quote
Old 11-03-2009, 03:25 PM   #3
NCedillos
Still The Best SPI
NCedillos's Avatar
Fan#: 50780
Probably 7 psi. I will have to build my tranny for anymore. I have an automatic, I will either be getting a lentech or swapping a manual. Not sure which route I want to go currently.
As of right now I will be using a t3/t4 but am contemplating using a turbonetics super 60 instead, I know someone who has one.
Old 11-03-2009, 04:17 PM   #4
PSIaddict
Fan#: 69248
What I Drive: 01 yellow zx3
FF Reputation: 1 PSIaddict Good Standing Member
crank pulley o2 sensors and coilpack i wouldnt touch unless there is something wrong with them
217whp 253ftq at 10 psi
precision turbo kit
new setup in the works
PSIaddict is offline   Reply With Quote
Old 11-03-2009, 04:20 PM   #5
NCedillos
Still The Best SPI
NCedillos's Avatar
Fan#: 50780
Crank pulley there is some wear on the rubber ring part of it causing it to wobble so I'm replacing that. o2 sensors are for 100,000 mile maintenance I've heard it be recommended. I already have all of the parts and they are being put on this week. I got everything crazy cheap. Other than the lifters were really expensive. Coil and wires were because before I was having some idle issues I figured since I was buying the wires from Massive that I would just buy the coil pack as well.
So basically consensus is am okay and probably good to go?
Old 11-03-2009, 09:01 PM   #6
PSIaddict
Fan#: 69248
yea you should be good, but im not really an SPI expert but i heard a lot of people droping valves on those engines. And im not sure what is involved in replacing the lifters but if head removal is necesery i would definitly look into freshening up the valves or at least looking at them to make sure evrything is in order
precision turbo kit
Old 11-04-2009, 12:46 AM   #7
ChuckDee
ChuckDee's Avatar
Fan#: 43589
yeh, 7psi should be fun to drive around and im lookin to boost my auto someday. but i have a zetec :)
zetec crew#232
Old 11-04-2009, 04:56 AM   #8
woowoo16
woowoo16's Avatar
Fan#: 68343
What I Drive: 2001 yellow zx3
FF Reputation: 2 woowoo16 Good Standing Member
I had a turbo cvh :) , not the 2.0, but the 1.9. its all basically the same. which manifold do you plan on using? i used the "RS" manifold and i had to custom make my clutch slave wich was a big pain in the ass. im excited to see this build it should bring back some memories :)
woowoo16 is offline   Reply With Quote
Old 11-11-2009, 06:21 PM   #9
ChuckDee
ChuckDee's Avatar
Fan#: 43589
update?
zetec crew#232
Old 11-11-2009, 06:52 PM   #10
ehancock
un1corn
ehancock's Avatar
Fan#: 53353
What I Drive: 2004 Twilight Blue D23 ZX5
FF Reputation: 14 ehancock Great Standing Member
Within the past two weeks we did an oil change, fuel filter, accessory belt, acc belt idler pulley, crank pulley, timing belt, timing belt tensioner, water pump, spark plugs, msd coil, massive wires, front and rear o2 sensors, and all 8 lifters. Her car runs AMAZING now. Idles and drives so smoothly. The random harsh ticking noise popped up a couple times since it was worked on. Her family friend thinks it's a valve getting stuck. That will have to be looked at a bit more thoroughly before boooOOOOst. Worst case scenario we get one of the updated/rebuilt heads off of ebay.
The current setup she has was put together by MUTTLEE if anyone here remembers him. It's a JGS manifold with a t3/t4 xspower turbo. The piping that he put together is top notch and is still in great condition. The turbo may be replaced with a super60. We also definitely need new oil lines, and will probably be upgrading the current wastegate and bov.
ehancock is online now   Reply With Quote
Old 11-11-2009, 09:49 PM   #11
ChuckDee
ChuckDee's Avatar
Fan#: 43589
sweet stuff. keep us updated!
zetec crew#232
Bookmarks
Search this Thread:
Advanced Search
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
