Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
#11 | ||||
Koni Sport struts
KYB AGX shocks Steeda springs stock ST/SVT sways Massive strut bar used to be ST but I got some 235/50/15 R888s for nearly free so I'm enjoying FSP right now.
Sedan Revolution #103 focus in storage. hit a rock with the oil filter and locked it up. gotta sort out a 351w 4 door fox first, then the focus gets a 2.5 commuting with a v6 5 speed mazda 6 wagon. |
| Sponsored Links | |||
Advertisement | |||
#12 | ||||
SCCA class: ST
Dampers: SVT Springs: SVT Front sway: SVT (21 mm) Rear sway: Adjustable Auto-X-ZTS (24mm)
#13 | ||||
class: st in the cincinnati region
dampers: kyb agx, setting #2 up front, 6 in rear springs: progress front sway: oem with moog links rear sway: eibach 25mm stiff as hell but go-cart handling, im trying to induce more understeer |
#14 | ||||
class: FSP Winnipeg Sports Car Club (Bad Lands Region)
dampers: SVT springs: SVT front sway: 24 H & R rear sway: Steeda 28 mm Works very well can wants to rotate nicely |
#15 | ||||
Focus autox'r
class: NON-porsche(PCA), st (scca)
dampers: Koni yellow adjustable-set at full stiffness springs: Koni sport springs FSB: AEM(eibach)22mm w/moog fsb endlinks,moog balljoints,polybushings RSB: Steeda 28.6mm
01 zx3 6k $, go fast bits 6 k$, beating a 08 zo6=priceless JUNE 2010 ROTM ZETEC CREW165 |
#16 | ||||
Thanks.
-Nick NaRdone NickNardone.com Follow me on Instagram for constant project car updates @NickNardone |
#17 | ||||
LETS TURN DIRT!!!!
I havent autocrossed but I have taken it to large road tracks..
Front Stock SVT Rear 25mm Eibach Ground Control coilover conversion kit - 500# single rate springs front and rear with Koni Yellows SPC Camber plates on the front
[B]1951 McCormick FARMALL M 2007 MINI Cooper S Turbo... new project car 1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel 2004 Harley V-Rod.... sex on wheels 2011 Harley Electra Glide Ultra Limited [/b] |
#18 | ||||
Focus Factor
Moog is an aftermarket endlind that is way beefier looking then the stocks. I would suggest them if you ever replace yours, i Plan to...I am running the saleen/eibach suspension on my SVT which is an Eibach pro kit with rear sway bar from the kit and a stock SVT front sway bar....NIce ride still and handles a little better then stock svt....as far as scca class, I am afraid to ask when I tell them what I have under the hood.
New Toy 2013 Focus ST3 Performance Blue 2011 F150 FX4 Blue Flame Metallic SuperCREW EcoBoost 371RWHP/458RWTQ 89 Mustang 5.0 Turbo 670 rwhp-Gone 07 Mazdaspeed 6-Gone 03 SVT Focus Turbo 326whp/278wtq-Gone |
#19 | ||||
I run on Toya RA1's - R compound tires.
Suspension - KW/variant II coilovers FWB - factory RSB - 28.6mm Camber plates up front Camber adjustable arms in rear Looking for that magic balance of oversteer. I see there are a few running the rear 28.6 mm bar...how is it working for you guys? - 1st time it sawed thru my lower control arms...bummer! egbertnr - Mazda Speed 6 - nice ride...how do you find the clutch?
Just..."get er done"! |
#20 | ||||
Token Engin-nerd
I'm hooking myself up with some new suspension this year... The wagon responds a bit differently from all of the other cars due to the rear damper orientation and progressive rear springs.
OLD: eibach pro-system for wagon (springs and dampers) (rears are progressive rate and overall a bit higher rate than the zx_ prokit rears) stock 21mm front bar stock 20mm rear bar with poly bushings Torsen (huge difference in response) This setup rotates like a merry-go-round, but turn-in is terrible, it oversteers a bit on exit and it is very unstable in transition. Synopsis: Eibach dampers are junk in the rebound department. So I wanted to get some rebound adjustability. Sadly, they dont sell Koni yellows for the wagon, I'd be stuck with Special D's. Luckily a very nice guy with a hot rod wagon pulled through... NEW: Eibach pro-kit springs (rears are progressive rate) Koni Yellow (sport) front dampers Bilstein PSS9 rear shocks ( )stock 21mm front bar with poly bushings stock 20mm rear bar with poly bushings Torsen I recommend the poly bushings to everyone since the stock ones dont allow the bar to work properly as an anti-roll bar... they make them more of a third and fourth spring on each side... Oh and I run in SM for other reasons. Not many SM cars in my region so I get bumped with the modded sti's and evo's
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Adding Rear Sway Bar | klodkrawler05 | Wheels & Tires - Sponsored By Tire Rack | 6 | 10-24-2007 08:37 AM |
| front sway bar, strut tower brace, stress bars...huh?! | stoopidsteve87 | Wheels & Tires - Sponsored By Tire Rack | 3 | 10-19-2007 04:43 PM |
| Progress Rear sway bar kits back in stock | Tony D | Group Buys & Hot Deals! | 0 | 08-20-2004 04:40 PM |
