Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Old 04-17-2012, 09:34 AM   #21
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2008 Edge SEL
FF Reputation: 32 tukaniSVT Great Standing Member
Nice.
-Ray-
22ST FF PHOTO CONTEST HAS BEGUN
CLICK HERE TO JOIN IN TO THE PHOTO FUN. ALL ARE WELCOME.
Hatch Nation Member: #147
TeamFocalize Head Honcho
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 04-28-2012, 09:47 PM   #22
rallyrussel
Fan#: 93593
What I Drive: 04 2.3L Rally focus
FF Reputation: 1 rallyrussel Good Standing Member
You should learn to use the oversteer to your advantage, In a front drive car the way to keep from spinning is the opposite of what you are currently doing. Mash the go pedal and point the fronts where you want to be. The tail will follow. Not the fastest way around all corners since you are bleeding energy while sliding, but a good way to get around some of the tight stuff that would other wise be painfully slow. Turn in... make a sandwich... rotate and go. A good example of where to use a drift would be a tight Chicago box, or set of 90° turns.
Also getting some front camber on a McPherson strut will help when you autoX.
-Rally Russel
check out my rally focus site:
Http://www.rallyrussel.com
rallyrussel is offline
Old 05-16-2012, 07:50 AM   #23
STS-focus
Fan#: 55097
What I Drive: 2000 Zetec sedan
FF Reputation: 1 STS-focus Good Standing Member
quickly, I run -2.4 camber in front per side, -0.18 toe front. -2.2 rear camber per, 0.0 rear toe. Eibach sways front and rear, front Koni yellows full stiff, rear koni 1-1 1/2 turns off full stiff. if she plows ill soften up the front half a turn. LFB FTW!
#87 STF MASSIVE SPEED SYSTEM 2000 Focus Sedan
2012 Chicago and Milwaukee Regions SCCA STF Season Champion
STS-focus is offline
Old 05-29-2012, 08:34 AM   #24
mac.mogul
mac.mogul's Avatar
Fan#: 90409
FF Reputation: 10 mac.mogul Great Standing Member
Front camber is going to change the car entirely if you've been running with NO front camber... Its definitely going to help to keep the front end from pushing through turns.
2011 SES 5spd #006 >> SR #213
Join the cause! 3 Door Fords for America! facebook.com/3DRS4US
The internet is for finding an answer, not for finding ways to ask a question.
mac.mogul is offline
