Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Sponsored By:
Tire Rack
Thread Tools Search this Thread Display Modes
Old 11-03-2009, 12:11 PM   #1
cconley
Fan#: 40920
What I Drive: 2004 Sonic Blue Focus SVT w/EAP
FF Reputation: 1 cconley Good Standing Member
215/40/17 Tire on SVT
Has anyone had any problems with this tire size on the SVT? Any problems with the ABS??? I know there will be a minor discrepancy with the speedo, but I'm not worried about that.
2nd, anyone know what it would cost to get the different tire size programmed into the computer at a dealer?
Thanks,
Chris
cconley is offline   Reply With Quote
Old 11-03-2009, 12:37 PM   #2
SkyPilot
Flight Instructor!
SkyPilot's Avatar
Fan#: 22350
What I Drive: 2004 Hertz Silver Ford Focus SE
FF Reputation: 33 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (14)
you will have no problems running that size tire, the difference in the size is a cm, so it will be about the size of a worn out 45 sidewall.
as far a reprograming the ecu, its such a small change it would be a waste of money in my opinion
ZETEC Crew #26
SEDAN REVOLUTION #20
Roush Stage 2 Suspension, MBRP Cat-back, Volant Intake, SVT 5 spoke rims, FC 65MM TB
The former focusman6297
SkyPilot is offline   Reply With Quote
Old 11-03-2009, 12:43 PM   #3
cconley
Fan#: 40920
Thanks for your 2 cents. I see you're a flight instructor... me too! Where did you go to school? I'm a UND grad. Teaching (privately) in central Iowa. Of topic, sry.
Other question is will sportlines cause rubbing on an SVT?
Old 11-03-2009, 02:19 PM   #4
dirtbrown
danky
Fan#: 40563
What I Drive: SVT
FF Reputation: 21 dirtbrown Great Standing Member
you should be fine with that tire size....why do you want the smaller sidewall?? even a 215/45 should fine with sportlines
dirtbrown is offline   Reply With Quote
Old 11-03-2009, 02:49 PM   #5
alex62390
alex62390's Avatar
Fan#: 60434
What I Drive: 2004 svt focus EAP
FF Reputation: 4 alex62390 Good Standing Member
i have 205/40zr17 on my car. i do not like them and i would not recommend getting that size. they came on the car when i bought it. it is different from what you are looking at. just a warning.
2004 svt focus EAP
1 of 62 infra-red EAP 3 doors
#658
alex62390 is offline   Reply With Quote
Old 11-03-2009, 03:50 PM   #6
misfire
Dipstick Underdog
misfire's Avatar
Fan#: 31379
What I Drive: 2010 Silver Focus SES, 2008 Mazda 3
FF Reputation: 17 misfire Great Standing Member
Buy-Sell-Trade Rating: (9)
yeah, the 205/40's suck.
i have 235/45/17 now. too big. lol. i rub on large bumps or inclines.
Sedan Revolution #151
Mid Atlantic Crew
Mid Atlantic Extreme Crew
FS Werks Engine Cover, FS Werks Front Strut Brace, Ford Racing Black Rally Wheels, Decals by zx360
misfire is online now   Reply With Quote
Old 11-03-2009, 04:28 PM   #7
SkyPilot
Flight Instructor!
SkyPilot's Avatar
Fan#: 22350
Originally Posted by focusp71 View Post
i have 234/45/17 now. too big. lol. i rub on large bumps or inclines.
im sure you meant 235, and damn thats a big tire for our cars.
here is a little tire math for everyone. we will use 215/45/17 for this
215= width of tire in MM
45= 45% of the first number which gives your sidewall hight, also called aspect ratio
17= of course 17 inch rim
tire widths increase by 10mm for every size 205, 215, 225 and so on.
as a rule of thumb +10 -5. when you upsize a tire to the next size you subtract 5 from the aspect ratio. and when you downsize you add 5 to the aspect ratio.
if you do the math 45% of 215= 96.75mm
if you upsize to a 225/40 and use the +10 -5, 40% of 225=90mm
Now 17inch rim is 431.8mm tall. times your aspect ratio by 2, add 431.8 and you get how tall the tire is.
Now this IS NOT going to give you the same rolling diameter of the original size, however it will get you as close as possible when going for a wider, or skinner tire. But always do the math to get an exact answer to figure out the hight of the tire to see if it will fit.
Also there is no standard on where the width of the tire is measured, this will vary slightly from each tire company, this also holds true for treadwear ratings, every company has its own standards for this. All companies test their tires the same way for the most part, but each has a slightly different rating scale.
ZETEC Crew #26
Old 11-03-2009, 06:01 PM   #8
cconley
Fan#: 40920
The new tires look much better. I think the drop from the sportlines will "make the car". I'll post a couple of pics of the new tires tomorrow.
The dunlops that were on the car when I bought it looked good, but when I bought the neogens they just looked too big so I decided to downsize.
Old 11-03-2009, 06:50 PM   #9
Geezer
Fan#: 1427
What I Drive: 99 miata, 03ZX3, 05Mazda6, 09GTI
FF Reputation: 123 Geezer Excellent Standing MemberGeezer Excellent Standing Member
Rubbing is primarily the result of offset, wheel width, and tire size, how much you drop, spring rates and shocks. It's a package. With the wrong offset a softer spring (the eibach sportlines start off soft with their progressive rates) will rub. Also if the springs are allowed to compress too rapidly (e.g. big hits) a larger (wider)tire may rub. Therfore, good shocks are absolutely necessary to control/dampen the spring. What offset wheel are you using?
Geezer is online now   Reply With Quote
Old 11-03-2009, 07:58 PM   #10
mlbbaseball
SNOWMOBILING 4 LIFE
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 01 zx3 s2 x2, 02 SVT, Jeep Cherokee
FF Reputation: 36 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (56)
as long as ur @ or below a 215/45/17, ur just fine.
SALE: 3 JRSC zetec SC's, Rally skid plate, s2 spoilers, Tires, Headlights, 65 mm tb duratec (pending), my LAST SVT JRSC w/ BBK and tuning voucher, 3" MAF, 2 zetec/svt turbo kits, built zetec/svt bottom end! PM me
mlbbaseball is online now   Reply With Quote
Old 11-06-2009, 12:24 PM   #11
myfafp3
myfafp3's Avatar
Fan#: 59725
What I Drive: 2000 Cloud9 Sport Saloon
FF Reputation: 3 myfafp3 Good Standing Member
I agree with mlb and dirtbrown. I had sportlines on mine with svt wheels and 215/45-17 tires for about a year with no problems. I even went with a 225/45-17 in the rear on the same wheels and didn't rub.
Posted via FF Mobile
myfafp3 is offline   Reply With Quote
Old 11-07-2009, 12:39 PM   #12
gregor_42
gregor_42's Avatar
Fan#: 51089
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 1 gregor_42 Good Standing Member
I have 215/40/17 right now and have had no problems so far. I would recommend watching out for the larger holes and bumps tho. I hit a big hole the other day and felt like my whole wheel fell off lol
"And with due respect to the Mustang Cobra, we think this car [the SVT focus] also adds up as the best thing the SVT consortium has done to date." - Car and Driver
gregor_42 is offline   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
